1994 Honda Accord NO SPARK
1994 HONDA ACCORD
121,000 MILES • 4 CYL • FWD • AUTOMATIC
JBT7THSF
HAVE REPLACED HEAD, NOW NO SPARK TO PLUGS NO FUEL PUMP, HAVE TESTED ALL COMPONENTS IN DISTRIBUTOR ,OK, AND REPLACED MAIN RELAY, PUMP WORKS MANUALLY AND CAN'T CHECK CODES AS NO LIGHT, BULB IS WORKING, NO LIGHT WITH KEY ON AND IF JUMP CONNECTOR STILL NO LIGHT. TIMMING IS SET TO SPECS. HELP PLEASE!!
THANKS,
JB
Jun 12, 2010 at 12:18 PM
F4I_GUY
  • 3,302 POSTS
The fact that the check engine light doesn't come on, even when you jump it is troublesome.
Either you have a blown fuse, blown ecu or the ignition switch has failed.
By the way, did you re-connect the ECU ground on the thermostat?
Jun 13, 2010 at 6:52 PM
