1994 Honda Accord help
1994 HONDA ACCORD
84,000 MILES • 4 CYL • 2WD • AUTOMATIC
KVAB123
in my Honda accord 94 the water pump is leaking that Avery time i have to go out to work i have to put water, now my problem is im really low on my budget to fix the car .Is there any other way that i can patch or seal the leaking for a while until i collect the money to fix it? any help please will much appreciated thanks
Aug 18, 2008 at 12:24 PM
KHLOW2008
  • 41,814 POSTS
Hi kvab123,
There are some stop leaks type of fluid that you can put into the coolant to let it cycle and patch up the leaks but if the leak is bad, it might not work.
You have to be very careful with the situation now as overheating can cause a lot of damages to the engine.
Aug 19, 2008 at 10:28 AM
