Other Category problem
1994 Honda Accord 4 cyl Two Wheel Drive Manual 250k miles
My name is Mike and my main hobby is Auto Repairing.
I'm going to be honest with you and I hope you can do the same with your answer. A couple years ago I was under Federal Investigation which come to find out they were following the wrong person. But during this investigation I found out that they popped the lock on my car. I then noticed that the 2 piece plastic cover around the steering column was loose and crooked. I never took this apart before and I seen that they forgot to replace all the screws.
I took out the 1 remaining screw and removed the cover which to my surprise their was a 4 wire plug on the SIDE OF THE IGNITION which ran under the dash. I know for a FACT that this plug has nothing to with starting the car. I disconnected the plug, pushed the clutch and turned the key on and my car started with NO PROBLEMS!!!! A couple days later they got back into my car (forgetting to lock it) and found a large gage jumper wire connected to 2 smaller gage wires under my dash. I then took my wire cutters and cut the wire. I then took my Ohm Meter and traced these wires to a circuit board behind the speedometer and rpm gage. I also found a 4"x3"x1" FACTORY INSTALLED METAL BOX under my dash but bolted to a metal plate and had a 20 to 30 pin plug on it. I unplugged it, pushed the clutch and turned the ignition key and my car started with NO PROBLEMS!!!!!! They got back in car again and did something else but I haven't had any time to look and see what they done. Could you HONESTLY tell me more about the system and I PROMISE that this information will remain confidential with me. My wife has a 2005 Toyota Matrix and I also found a plug on THE SIDE OF THE IGNITION which I disconnected BUT the car would not start and I know for a fact that the wire DOES NOT GO TO THE STARTER. I'm pretty sure you can get information about the system and if possible can you get the complete schematic.
I'm not in a rush but I hope you will take the time to get this information for me.
P.S I sent a $10 donation
Feb 5, 2008 at 6:02 PM
