1993 Honda Accord white smoke coming from exhaust
1993 HONDA ACCORD
99,000 MILES • 4 CYL • FWD • AUTOMATIC
ERIC195
When I start the car when it is cool I get a lot of white smoke. This usually disapates after the car is warmed up. I recently had an oil leak from the oil filter o-ring repaired. I thought this was causing the smoke, however the smoking continues. What else may be causing the smoking?
Jan 12, 2008 at 2:43 PM
BRUIZER
  • 35 POSTS
Head gasket leaking coolant into cylinder...ck coolant level...will only get worse. Had Civic ...did the same.
It will permanently damage engine.
Jan 12, 2008 at 3:09 PM
ERIC195
I checked, radiator level remains constant. My oil level drops, I think its a seal or gasket leak. I tried leak stopper, it help a little. I'm gonna try replacing the valve seals. What do you think?
Feb 2, 2008 at 7:17 PM
BRUIZER
  • 35 POSTS
Blue smoke= oil burning Blk smoke = excess fuel mixture White smoke= coolant leak in engine Still say it's the head gasket...refilling from expansion tank on cool down..ck the coolant level there.. older cars use oil....it's no big deal,,,,,,,
https://www.2carpros.com/forum/automotive_pictures/128479_exp_tank_1.jpg
Feb 2, 2008 at 7:44 PM
