1993 Honda Accord Starter Relay?
1993 HONDA ACCORD
TPVERO
Electrical problem
1993 Honda Accord Two Wheel Drive Manual 125000 miles
I recently had a problem with my car not starting and was told that it was because of my starter. I replaced the starter and had to old starter tested, which was definately bad. Now the car still won't start. I have full power and when I turn the key it clicks, but doesn't start. Could the issue be the starter relay? And where is it located?
Jun 9, 2008 at 2:47 PM
MERLIN2021
  • 17,250 POSTS
Clicking? or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good!
Jun 9, 2008 at 2:49 PM
KHLOW2008
  • 41,814 POSTS
Hi tpvero,
Did you replace with a new or used starter?
If used , did you test it brfore installing?
Jun 10, 2008 at 10:42 AM
