1993 Honda Accord No power
1993 HONDA ACCORD
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRCCHIN
New battery installed, horn works no other electrical componets working. All connections to the battery are clean and no lose wires.
May 9, 2009 at 6:59 PM
JERRYGOODWRENCH
  • 77 POSTS
check the ground wire on engine block and body connections. let me know..
May 10, 2009 at 6:17 AM
MRCCHIN
the connection is good at both locations
May 10, 2009 at 1:01 PM
JERRYGOODWRENCH
  • 77 POSTS
possible bad ign switch or wiring harness that runs through firewall. If wiring harrness has a plug in connector ,un plug and clean those pins and check for any that may be misaligned. also check starter wires and make sure all connections are clean and tight. Sometimes it's just a process of elimination..Let me know..
May 10, 2009 at 4:41 PM
