1993 Honda Accord Brake lights don't work
1993 HONDA ACCORD
DMARIE5500
Electrical problem
1993 Honda Accord 4 cyl
My '93 Accord's brake lights don't work. All other lights-tailights, headlights, reverse-do work. The taillights just won't get brighter when I apply the brakes. I tried fuses, but could not find one for this problem. I replaced both taillight bulbs as well as the rear window mount light bulb. I put in a new brake lamp switch under the steering column. I tried to remove the lighting relay under the hood fusebox, but didn't want to pull any harder not knowing if I would break it or even knowing IF I can take it out. I'm a broke college girl and cannot really afford to take it to a professional. Any advice? Any knowledge of the possible cost of having to take it in? Help would be tremendously appreciated...
Thank You-
Scared To Drive In Wisconsin
Mar 30, 2010 at 2:14 PM
KHLOW2008
  • 41,814 POSTS
Hi dmarie5500,
The stop light fuse is in underhood fuse box, did you check that?
Are the horns working?
Apr 2, 2010 at 11:32 AM
