No repairs, I just start notice the change in the rpms and the gas mileage getting worst. No lights on, all of my cluster lights are off, the only one that comes on is the cruise control when I turn it on, that is it. When I start noticeing the higher rpm, I was told to do a tune up, so I did, and ever since a roll this car out of the car lot in 1993 I had always use genuine honda parts, everything, rotor, cap, wires, spark plugs, gas filter, trans fluid(change every 50,000 miles), belts, seals, power steering, racket pinion. Maybe is just too old 350000 miles. I even replace the ECU with an original, I did take both of the ECU out and open them up and did't see any burn transistors\parts. Thanks for you help, please let me know if there is any thing I should check for.
Oct 27, 2010 at 11:38 PM
