last i noticed that upon acceleration that my car sputters then would burst back to normal driving. this started happening and about usually under 1500-2000 rmp. Did diagnosis and got 3 codes (#7-throttle position sensor, #14-oxygen heat sensor, #41-oxygen sensor). Replaced the TPS (used) due to dealer nor shops sell this separate with out whole throttle body assembly. Well after replacing with a couple of these the car still responds the same. Also noticed that the TPS installation reflects the performance (like timing adjustment) from fluctuating idle to back fireing. How can this be adjusted and or does the oxygen sensor still have anything to do with this problem? I sure can't pay $600 for a throttle body assembly just for this one particular part. No other codes are showing up either. Need Help..
Aug 6, 2008 at 9:16 AM
