Transmission problem
1992 Honda Accord 4 cyl Front Wheel Drive Automatic
My wife has a 92 accord with a AT. Sometimes the car will not go into 4th gear. D4 light starts flashing. Leave car sit overnight drives fine for the next couple days. I could only find the DTC codes for the a 93 on the web. If I put a jumper on the "Service Check Connector" it states the "S" indicator light should flash. The 92 does not have that but the "Check eng" light and the "D4" flash. CE 6 flashes (temp sensor prob) I can fix that. D4 gives one flash slowly. I cross that to the 93 DTC's that mean "lock control solenoid" problem. Can someone confirm this code for a 92 accord.
Dec 2, 2008 at 11:11 AM
