1992 Honda Accord Oil cooler O-ring
1992 HONDA ACCORD
222,450 MILES • 4 CYL • 2WD • AUTOMATIC
BUBBAENGLAND
I have a slow oil leak, I've located it, and would like to know if I can replace the oil cooler O-ring myself, and how?
Mar 18, 2009 at 12:05 PM
KHLOW2008
  • 41,814 POSTS
Hi bubbaengland,
Remove oil filter.
Remove centre nut (threaded section of oil filter seat) Some models have 3 pcs of 10 mm hex bolts that has to be removed.
Disconnect coolant hoses. (Drain radiator and engine block before attempting work.
O ring can be replaced.
Reverse procedure for installation.
Replace hoses if hardened.
Mar 23, 2009 at 10:00 AM
