I've had a problem in the past with putting my car into say, D3, but the gear indicator on the dashboard will blink on D4, and i will need to manually shift the gears as I drive down the road because it is stuck in too high a gear. This problem seems to correct itself if I turn the car off and let it sit for a few hours.
I've recently had a problem with my car not starting. It will turn over fine, but not make the final push into starting up. I've also have to replace the coolant relitively frequently in my radiator, and anything I put in my overflow tank either leaks out or is being sucked into the radiator rapidly.
When I replaced my spark plugs today, I noticed they were slightly white colored. I believe this means my engine is too hot. Also, one of the spark plugs was filthy with oil, and one had a bunch of gunk on the upperside of it.
Any suggestions?
Any suggestions?
Jul 12, 2009 at 8:33 AM
