1992 Honda Accord how easy to replace the starter
1992 HONDA ACCORD
193,000 MILES • 4 CYL • FWD • AUTOMATIC
STEVE IN KC
I have changed many starters before on vehicles where the starter is located underneath, but on my 1992 Accord, it is mounted on the left side of the engine.
It looks pretty tight in there.
Any tips to be aware of when replacing this? Is this something a Honda newbie could do?
Nov 12, 2009 at 11:01 AM
HONDA TECH 1818
  • 536 POSTS
Yes, you can DIY. First you will need to disconnect the battery negative terminal, then the starter solenoid wire and the 12mm bolt that holds the 12 volt cable from the starter. There is a 14mm bolt on top and a 17mm bolt on the back bottom of the starter. The 17mm bolt could be very tight so you will need a 1/2 inch breaker bar to get loose.
Nov 13, 2009 at 2:15 AM
SHERRYL GRAHAM BURRIS
I know the bottom bolt is 17mm, but what is the length?
Aug 27, 2018 at 12:08 PM
FREEMBA
  • 1,152 POSTS
The bottom bolt is 4.5 inches long (that is equal to 114.3 mm).
Aug 27, 2018 at 7:26 PM
