I put it in g gear D4 and it starts blinking
1992 HONDA ACCORD
150,000 MILES • 4 CYL • AWD • AUTOMATIC
ZMENCHACA
What can be wrong when i'm driving mycar i put it in g gear D4 and it starts blinking like emergency hazards light. the problem started about 3 days ago
Sep 17, 2010 at 11:59 AM
SQM
  • 6,383 POSTS
When the D4 light flashes, it indicates an error form the transmission control module (TCM).
In order to know what the error might be, you will have to retrieve the transmission code(s). That can help with the diagnostics.
To pull the code, remove the kick panel on the passenger side and look for a set of wires with blue connector.
Use a jumper wire between the two pins (can be done using a paper clip or piece of wire).
Turn the key to the on position.
The D4 light will flash the code.
Short flash equals 1 and long flash equals 10.
Add the numbers to get the code.
https://www.2carpros.com/articles/honda-car-1990-1995-obd1-code-retrieval-procedure-and-definition-table
I have attached the code list below.
Thank you.
Nov 10, 2021 at 2:00 PM
