KHLow2008 I had chack thermal sensor in the past and looks like thsese type of sensors are not all the same...the sensors are good(found out after spending big bucks on new ones).
Automatic Transmision
my problem is the transmison will not upshift these happened when the S switch was pressed or activated now is erratic even after I disconected the battery cable to erase the codes(I also disconected the S switch is that OK?)I try checking for a code but the S light blinks inttermitent or it goes off and the transmision works ok.
I really can do without the S switch function
I like to know what is causing that I have removed and checked the Speed Ctrl. Solenoids(applied 12V and sounds like they activate(clicking sound)
Another question is it common on Honda cars to have poor conection between points I've been reading on a manual and it talks a lot about poor conections between connector wires.
I have removed and cleaned the conectors for the ECM and A/T control unit it did not make a diference.
thank you for your help
Jul 14, 2020 at 12:58 PM
(Merged)
