My brake warning light is on and my car has gone into limp mode. All brake lamps checked out ok. Fuses are OK, No codes when we jumper the connector. The TCU not bad bad components. Any suggestions on what else should be checked to fix the problem. I had the car at two different shops. The first said it was the transmission, the second supposedly fixed it with new brake light . lamps I can't afford the high diagnostic costs. I hope you have some suggestions for me.
Could a problem within the ABS system cause the car to go into limp mode ?
Thank you
Thank you
Jan 5, 2010 at 2:13 PM
