1991 Honda Accord Hi my name is mike and my honda does not
1991 HONDA ACCORD
177,000 MILES • 4 CYL • FWD • AUTOMATIC
KALLASHNIKOV
What happened is that i was driving the car and all of the sudden it just stopped and shut off. I park it at the side and tried to turn it on again. After a few tries it started and then it did the same thing again after five min. I changed the computer because i was not getting any electrical in my ignition cables, changed the fuses and they are all fine. I don't know what it could be. If you could help me would be great, thank you for taking your time to read this message.
Sincerely, Mike Pojani
Apr 27, 2008 at 3:04 PM
Do below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Apr 27, 2008 at 4:12 PM
