1991 Honda Accord Clutch not working - PLEASE help
1991 HONDA ACCORD
MARTINYMICHELLE
Transmission problem
1991 Honda Accord 4 cyl Manual
I had the clutch replaced and the car drove great for a few days. Then it started to freeze up. It would get really tight and wouldn't shift to the point of having to pull over and pump the clutch until it would work again (usually 10-15 seconds) Now the cllutch pedal just goes down to the floor and does not shift into any gears. I was told it was probably the slave cylinder so I had that replaced and bled and it did not work.
May 6, 2008 at 8:37 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
if you have good pedal pressure and the slave cylinder is pushing the clutch fork, fully, you will have an issue with in the clutch ass. but first ensure that the master cyl is not leaking and you have good pedal pressure (no air still in system)
mark (mhpautos)
May 7, 2008 at 5:44 AM
