changing out alternator?
1988 HONDA ACCORD
169,875 MILES • 4 CYL • FWD • MANUAL
JDIZZLE420247
what is the EASIEST way to remove AND replace my alternator in my 88 Honda Accord DX???
Dec 22, 2009 at 8:45 AM
KHLOW2008
  • 41,814 POSTS
Hi JDizzle420247,
You will need to remove the drivers side CV axle to get the alternator out here are guides to help you get the job done with diagrams below.
https://www.2carpros.com/articles/replace-cv-axle
and to walk you through the steps.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Cheers
Dec 24, 2009 at 12:56 PM
JOSHBRANDT16
for my 89 i had to undo the enigine mounts not all the way just loosen... then take drive axle off.. then jack engine up about 2 inches and should come out
Jan 2, 2010 at 4:37 AM
DGIMESON
My Answer 1. Disconnect battery 2. Remove Air Cleaner (4 clips and slide up and out) 3. Remove Air Cleaner Box (2 10mm bolts and low clip) 4. Remove Alternator tension bolt, move belt out of the way 5. Remove Alternator pivot bolt, lower part of Alternator 6. Disconnect wire clip from back of Alternator 7. Slide Alternator back towards firewall and were the Air Box was. Ta Da 8. Disconnect wires, left Alternator straight up and out. Install in reverse order (8-1) This worked for me. Remember to safety first.
https://www.2carpros.com/forum/automotive_pictures/467800_88AcrdAlt_5418_1.jpg
Jan 21, 2010 at 11:12 AM
