1987 Honda Accord My Brake lights stay on
1987 HONDA ACCORD
16,300 MILES • 4 CYL • 2WD • AUTOMATIC
TIM742
My brake lights will stay on after the ignition is off. I was told that the the brake light switch needs to be adjusted or replaced how do i go about doing that?
Jul 27, 2008 at 5:28 PM
Follow the brake pedal arm till it meets up at the brake support bracket its there-while brake is being applied the plunger should extend and not being depress by the arm-
Jul 27, 2008 at 5:34 PM
PRKUSH
  • 5 POSTS
switch located near the brake pedal,
look for a worn/missing plastic pad which keeps the switch pressed and so the light 'off' and is available as a replacement part. as a short term fix put a few wraps of thick tape on the pedal to fill the hole
Jul 31, 2008 at 7:38 AM
