1986 Honda Accord Starts, dies after 2 minutes
1986 HONDA ACCORD
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
ONEFREQ
The car starts easily, then idles at high rpm for 2 minutes, then dies. Doesn't run rough.
It will keep running if, I continue to manually choke it.
I replaced the spark plugs, fuel filter, fuel pump, to no avail.
Any ideas? Thanks!
Jun 21, 2010 at 2:41 PM
KHLOW2008
  • 41,814 POSTS
Hi onefreq,
Thank you for the donation.
If depressing the accelerator to increase the engine speed keeps the engine running, then you need to check the idle speed adjustment.
Is this an injected or carburetted model?
Jun 21, 2010 at 4:37 PM
ONEFREQ
It is the carburetted model.
Depressing the accelerator to increase the engine speed does NOT keep the engine running.
The only way to keep it running is manually choke it.
Thanks!
Jun 21, 2010 at 5:46 PM
KHLOW2008
  • 41,814 POSTS
There are a few possible scenarios.
1. Fuel float level too low. At the sight glass check if the fuel level is 1/2 way or slightly higher.
2. Vacumn leakages. If any vacumn leaks occurs, insufficient fuel would be drawn into the manifold and cylinders. Check all vacumn lines and PCV for leakages.
3. Fuel cut solenoid not working or stuck in closed position. The fuel cut solenoid at rear of carburettor should click when the ignition switch is turned on.
Jun 22, 2010 at 7:37 AM
