1986 Honda Accord Recommendations Questions
1986 HONDA ACCORD
RTHALE
Engine Performance problem
1986 Honda Accord Front Wheel Drive Manual 202000 miles
I finally got my Accord running, it was the starter selenoid, replaced the starter and with a little carborator cleaner as starter fluid fired up...
Now, runs very smooth, idles just under the 2 on the rpm gauge steady.
This car had sat for 2 years, what recommendations can you make....i.e. oil change, plugs.
Anything that you can think I should look into replacing due to sitting so long. Also since there are so many miles on it is there a really really good oil I should use instead of just plain 10-30 ?
Now that its running anything I should look for or check on?.....Tks
Apr 25, 2008 at 9:36 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
It would be a good idea to change all the fluids, coolant engine trans and brakes. Yous the oil you have been using that should be fine. It would also be a good idea to drain the fuel as it will be stale,and change the filters as well.
Mark (mhpautos)
Apr 25, 2008 at 9:47 PM
LEGITIMATE007
  • 5,121 POSTS
uhh, you could probably just change the oil three quarts and a quart of mystery oil to keep it good. um, go ahead and do plugs and wires.
Apr 25, 2008 at 9:48 PM
