1984 Honda Accord replacing rack and pinion
1984 HONDA ACCORD
BRED
Steering problem
1984 Honda Accord 4 cyl Two Wheel Drive Automatic
how to get to the power steering shaft joint cover and disconnect steering shaft at coulping
Jun 7, 2008 at 9:57 PM
KHLOW2008
  • 41,814 POSTS
Hi bred,
From under the steering column above the pedals, remove the plastic cover, remove 2 spring clamps and 3 lock buttons at base.
Remove the lower bolt, unloosen upper bolt and slide coupling upwards to get the coupling out at lower end.
Jun 8, 2008 at 12:06 AM
