Hi, I'm having some clutch trouble on the ol Honda, are you available for a quick question, here's the the story. As I pulled into my parking space and pushed the clutch pedal in, all of the sudden, the normal pressure or resistance of pushing the clutch pedel in went "limp" and the pedal just pushed to the floor like a ballon that just let all the are out. Now the pedal will stick in the down position or I can grab it and it will pop quckely back to the up position. This is a straight cable with no hydrolic assistance. When having someone move the clutch pedal back and forth between the down and up postions, and watching the other end of the cable where it interfaces with the clutch arm, there is some movement but not enough to disengage the clutch. The clutch cable tension adjustor is in it's normal position as far as I can tell. What do you think may be the problem?
Nov 11, 2013 at 1:34 PM
