Hello, I have a two year long problem with my vehicle. When I turn right, the car is pulling to the right, like something "rubbery", elastic, is turning my steering wheel. If I stop and make a small left, the car drives straight. If I take a left turn, the steering wheel returns to center and everything is perfect. I have the car since new and two years ago it started to pull to the right. First I checked for an alignment problem (done over thirty times at different Honda's and other services). No problem. Switched tires. Nothing. Tried with winter tires, same. Checked everything in the suspension parts, replaced front bushings (only the big rear ones, they said that the front small ones are okay and that it has no play there), shock absorbers, spring seats, brake discs and pads, even if there was no play. Same thing. Every mechanic said it's the rack and pinion. Took out rack and pinion, the mechanics said it is like new, no leakage, no binding " Put it back, check something else". I even did a flush of the power steering system, maybe it' s something in there. Nothing changed. It just drives me insane, imagine going for 600 km on the highway hanging onto the steering wheel. Now, the only things I can think about are broken motor mount (lower torque rod) and I plan to change it, even though I do not think it can be related to steering, or something weird in the steering pump, but it should do this on left and right, not only to the right (I think). Any ideas? Thank you very much.
Jul 22, 2016 at 2:52 AM
