Engine idles high after backfire?
2006 HOLDEN VIVA
200,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
ROD LYONS
Whilst towing a heavy load i roll jump started down a steep hill in first gear. i only rolled a couple of meters then jumped it. The engine shuddered a few times, fired up and almost simultaneously backfired from the engine with such force it swelled the bonnet i swear; and blew off the top plastic cover of the box where the air goes to the manifold. this was factory glued down i believe. The cloud of smoke which plumed out from under the bonnet was immense and the explosion was so loud that all the neighbors came running out. I would have sworn I'd blown the engine but surprisingly it started 1st pop. that's when it started going straight up to 3 or 4 thousand revs, maybe higher, and just stays there. I have replaced the idle control, throttle control, and i think the third was air flow sensor. don't quote me on that last sensor but i did replace the three most recommended ones, I also glued the lid back on, all to no avail as nothing changed. I'm still searching for any air or vacuum leaks. is it likely a small leak would cause such a high rev though?
Dec 23, 2024 at 7:34 PM
BORIS K
  • 836 POSTS
It sounds like there might be an intake air leak.
A good guide on high idle:
https://www.2carpros.com/articles/engine-idles-too-high
How to find an air leak:
https://youtu.be/xN5pcM-5bso?si=B7tJmqHoO1nwOMfa
Hope this helps.
Cheers, Boris
Dec 24, 2024 at 6:35 AM
