problems with two electric windows?
1997 HOLDEN STATESMAN
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
BROCK FORD
I own a 97 VS statesman. I'm having problems with two electric windows front drivers partly works going down you have to push but coming up is fine, the back drivers doesnt work at all the other two are fine can you give me some advice thanks.
Aug 20, 2009 at 11:12 PM
We are going to have to start with testing the window switch and see if this is the issue.
We don't have a manual on this vehicle because it is not offered here in the USA but we do have a number of guides that will help with this.
Here is a guide on how to remove the door panel and then a video on how to test the switch:
https://www.2carpros.com/articles/door-panel-removal
https://youtu.be/HBFBcJrdym4
Also, here is a guide on how to use a test light in case you need a little more info on this:
Once we run through testing the switch the only other likely cause would be the motor so let's start here and see what results we have.
Thanks
Sep 24, 2021 at 3:32 PM
