Engine Mechanical problem
1995 Holden Statesman V8 Two Wheel Drive Automatic
Car has run out of petrol. Has been refuled with 20 Lts and ran for a while then another 20 Lts was added and the car will not run. Fuel filter has been replaced and was clogged. Fuel is getting to the injectors, the injectors are receiving and elec signal, there is spark, plugs gave been cleaned and computer puts out code 12 which i am lead to believe is the code for everything is ok. Will crank well and even with areostart will not fire.
May 6, 2010 at 2:55 AM
