1979 Holden Premier 308 problems
1979 HOLDEN PREMIER
304VNHOLDEN
Engine Mechanical problem
1979 Holden Premier V8 Two Wheel Drive Automatic
308 kingswood ute, fitted with a brand new holley street avenger 570, new plugs, leads, dizzy cap, problem starts and idles fine but when i accelerate it stalls so i pump it to keep it going, then when i run it under load it starts back firing out the exhaust, the timing is at 8 degrees tdc it has a electronic dizzy fitted there are no air leaks, does anyone have any brilliant ideas what might be wrong
May 28, 2010 at 9:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to check that the float level is OK, there is no guarantee that it will be correct from the factory, start here.
mark (mhpautos)
May 28, 2010 at 11:31 PM
304VNHOLDEN
there is no lack of fuel
float levels ok primers are working
May 29, 2010 at 5:16 AM
MHPAUTOS
  • 31,937 POSTS
I would go get the exhaust emissions check, make sure that it is not to lean, are the throttle pumps working?
Mark
May 29, 2010 at 5:24 AM
