Engine Mechanical problem
1979 Holden Premier V8 Two Wheel Drive Automatic
308 kingswood ute, fitted with a brand new holley street avenger 570, new plugs, leads, dizzy cap, problem starts and idles fine but when i accelerate it stalls so i pump it to keep it going, then when i run it under load it starts back firing out the exhaust, the timing is at 8 degrees tdc it has a electronic dizzy fitted there are no air leaks, does anyone have any brilliant ideas what might be wrong
May 28, 2010 at 9:07 PM
