2006 Holden Commodore 6 cyl Automatic 63000 miles
Could anyone help me to find out if there is any problem in my car.
When the gear is in neutral (gear not engaged at all), I depress the pedal to accelerate (to rave). When it crosses around 3000 rpm the car vibrates (rocks a bit). It happens all the time when I rave it without engaging the gear, not applying the brake as well. The car is still under warranty. I'd sent it to Holden repair centre to fix it twice. The report only indicates, engine vibe -> checked. However the problem remains the same.
I have tested on other car of the exact model as mine and other make cars such as Honda and Toyota. They do not have this vibrating problem.
I am thiniking of lodging a complaint to Holden. Could someone verify that my car has engine problem.
Thank you.
Thank you.
Feb 19, 2009 at 2:24 AM
