1997 Holden Commodore clutch fluid leak
1997 HOLDEN COMMODORE
ANDREWS88
  • 4 POSTS
Transmission problem
1997 Holden Commodore 6 cyl Two Wheel Drive Manual
The leak is coming from inside the gearbox ever time l try to bleed it where would the leak be coming from because it not leaking at the slave cylinder is ok
Jun 15, 2009 at 12:30 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There is no hydraulic component inside the gear box the only hydraulic item is the slave cylinder, hose & master cylinder, if you have a leak at the gear box it must be the slave.
mark (mhpautos)
Jun 15, 2009 at 5:21 AM
