1994 Holden Commodore leaking coolant
1994 HOLDEN COMMODORE
SCOTT W2
1994 Holden Commodore 6 cyl Two Wheel Drive Manual
why is there coolant leaking from rear bottom of gear box
Oct 28, 2009 at 4:59 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
Is it coolant? The A/C drains are above the transmission and you may be seeing drain off from the A/C condenser, pressure test the cooling system, and if this is coolant, you will have a leak in the heater core.
mark (mhpautos)
Nov 3, 2009 at 4:08 AM
