2003 Holden Barina Fault codes PO300 and PO301
2003 HOLDEN BARINA
RUSSBAX
Computer problem
2003 Holden Barina 4 cyl Front Wheel Drive Automatic 80000k miles
Engine intermitantly miss fires. Check light comes on. Scan tool shows two codes. PO300 miss fire detected cylinder one. PO301 random/ multiple miss fires detected. Plugs and coil pack removed and inspected, no obvious defects found. Plugs and coil pack replaced, fault still present. Vehicle has come to me after being at two other workshops including Holden dealership, still not fixed. I have two Barina's now in my workshop a 2001 and a 2003. Both doing the same thing, the same symptoms, same codes. I'm guessing this is not a one off fault because I have two of them doing the same thing so I'm hoping someone has struck this fault before and can help me. Regards Russell
Mar 12, 2009 at 11:07 PM
P0300 Random misfire-normally caused by vacuum leaks and bad fuel
P0301 Misfire at cyl no.1-check the sparkplug/compression/injector for no.1 cyl.
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Mar 12, 2009 at 11:21 PM
EXY
Did you ever resolve this issue. Were having the same problem at ther moment.
Jul 28, 2010 at 3:16 AM
