Check engine light is triggered, and the code is P0030. The H02 sensor is new from Mini (P/N is 7595353-03. it is the correct part for my vehicle listed above base 1.6, manual transmission).
Can anyone provide the wiring diagram showing the function and the resistance values for the Ho2, or as a minimum the heater circuit? I have confirmed that +12 volts is present from the ECU, as is a -ground.
Many thanks.
Many thanks.
Mar 17, 2022 at 8:01 AM
