I have a hissing noise when the car is warmed up, it is not there unless i drive the vehicle for a bit. I tried disconnecting the connector and hose to the purge valve when the car was started and warmed up to see if there was any suction or vacuum but there is none. I tried spraying wd-40 around the hoses but the idle did not change. II know it is somewhere in that area but i cannot find out where, for the life of me. I do have some low idle at rare times, the low idle occurs is when i go for a long drive shut the car off then restart it, the evap small leak detected code came up. I cleared the code and it never came back but i still hear that hissing noise when the vehicle is warm. Would be appreciated if someone could point me in the right direction of where the common leaks occur. Also, can a purge valve still be faulty even if there is no suction?
Oct 17, 2023 at 8:31 AM
