Hello again.
If all the fuses, relays, and new multi-function switch are in working order then it sounds like you have a wiring issue. Here is a tutorial on how to test wiring:
I've attached a picture wiring diagram below of your exterior lighting system for your car. I've cut the picture into 3 pieces so you can view larger. I would first check the ground that I've circled in red as a start .Check to see if the connection is not damaged, loose, corroded, or otherwise faulty. Let us know what you find and we'll go from there. Hope this helps and thanks again for using 2CarPros.
Danny-
Mar 8, 2021 at 3:04 PM
