High Temp. gage up and down
1993 OLDSMOBILE
120,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
MICKEYH
My Oldsmobile temperature gage inside the car will show over heating with needle going to max temp and seconds later going back to normal temperature just as quick. I have replaced the intake manifold gasket, temperature sensor, thermastat and radiater cap. I also have tried to burb the system by placing a no spill funnel on the radiater fill inlet and let run for over an hour. The car would burp every few minutes when what I believe was when the thermostat opened and that is when the temp gage inside would go to the max.
Feb 5, 2015 at 5:48 PM
TY ANDERSON
  • 719 POSTS
Have you used a thermometer to see if the car is actually overheating? To me is seems to be more electrical because temperature shouldn't change quickly. So, either the wiring is grounding causing the temp gauge to spike and return. Or it could be the gauge itself acting up.
Disconnect the temp sensor and the gauge should read cold. Place a wire in each terminal on the connector to the temp sensor and the gauge should read hot.
Feb 5, 2015 at 7:59 PM
