Hello, Sorry long post. I am experiencing late shifts (ie, high rpm shifts) with my transmission. The vehicle is listed above it is the XI model with the GM A5S390R aka 5L40E steptronic transmission. I first noticed the issue driving through a park (fifteen mph speed limit), the car would not up shift unless I gave it more gas. Since, it has been happening specially after long drives with the AC on. There is a noticeable whine in low gear. Took it to two transmission places and they said transmission is fine. As of late I have noticed that if I press the throttle pedal lightly the car vibrates for a split second as the car starts to move and also I have to press the gas pedal further for the car to move faster, as if there is no low-end torque. The car shifts smoothly up and down when it does. Fast acceleration is smooth and precise. Leisure drives are not possible. One day after about two hours of highway driving, I got off the highway and the engine sounded louder than usual and there was a noticeable pop pop pop exhaust sound as I waited for a light to turn green, perfect idle! No MIL, engine or transmission codes. I know it is a lot but I would be grateful for your expert advise.
Aug 19, 2017 at 11:35 AM
