High RPM, low acceleration
2008 MITSUBISHI LANCER
101,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
JUSTIN NEUMANN
  • 5 POSTS
So recently when I would try to accelerate my rpm's would rise, but the cars acceleration would not match. I thought the clutch may be slipping because it corrects its self eventually. This only happens every so often. What other problems will cause a vehicle to do this? ( Note: there is a stage two clutch in it now that only has about 7000 miles on it.)
Feb 12, 2018 at 7:28 PM
MHPAUTOS
  • 31,937 POSTS
really only a clutch fault will produce this type if concern. is there any smell when it is slipping?
Feb 13, 2018 at 4:10 AM
JUSTIN NEUMANN
  • 5 POSTS
No there is no smell.
Feb 13, 2018 at 9:53 PM
MHPAUTOS
  • 31,937 POSTS
Do a stall test; start engine apply park brake firmly select first gear and try to drive off the car should stall if the clutch slips it will be faulty.
Feb 13, 2018 at 10:38 PM
MHPAUTOS
  • 31,937 POSTS
Do a stall test, start engine apply park brake firmly select 1st gear and try to drive off the car should stall if the clutch slips it will be faulty
JUSTIN NEUMANN
  • 5 POSTS
The car stalled, this “slipping” problem does not happen often. Maybe once a week or so. I am so confused. Because since I made this post it has been fine. Are you sure no other problems could be the cause of this? Someone told me it could be my thrust bearing. Could that be it?
Feb 14, 2018 at 4:27 AM
MHPAUTOS
  • 31,937 POSTS
thrust bearing will not cause this. if the revs are high and you have little or no drive the clutch is slipping, other factors may come into play, a sticky pressure plate or a faulty pressure plate, binding hydraulic system, may be holding pressure on the clutch causing it to slip. the thrust bearing is attached to the clutch fork and when hydraulic pressure is applied to the slave cylinder the fork is pushed and the thrust bearing transfers the pressure to the pressure plate releasing the drive plate.
Feb 15, 2018 at 3:12 AM
JUSTIN NEUMANN
  • 5 POSTS
This is what I figured I was just going off of what someone had said. Should not have second guessed myself. Well looks like a new clutch is in my future. I should probably change the throw out bearing and stuff too huh?
Feb 15, 2018 at 5:05 AM
Yep change the disc pressure plate and throw out bearing. Here are guides to help you see how the job is done.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
and
https://www.2carpros.com/articles/how-to-replace-a-clutch
and
https://www.2carpros.com/articles/throw-out-bearing-replacement
Feb 17, 2018 at 11:53 AM
