High RPM's In park
2004 CHEVROLET MALIBU
98,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
KYLERCRAM02
Cold started my car after a few days of sitting because i couldn't drive it... (Some type of problem with CV axle or something... Looking into it) anyways.... It was jumping up to around 1,300 RPM's while in park. But as soon as I switched to drive or reverse it went back down to normal.. Around 600.
Jan 10, 2020 at 10:49 AM
Good afternoon,
This could be caused by a dirty throttle body plate.
I would start by having the throttle body cleaned of all carbon build-up.
Are there any codes set?
I attached some information for you on cleaning the throttle plate and how the idle system is controlled.
Jan 10, 2020 at 11:57 AM
KYLERCRAM02
Throttle body would make reverse and drive higher in RPM too... Not just park though... Right?
Jan 11, 2020 at 9:00 PM
Correct. the ECM controls the operation of the motor on the throttle body.
Jan 12, 2020 at 1:05 AM
