The car starts and idles smoothly, idles between 1,500 and 2,000 rpm's very slight dip in idle seldom.it also changes to overdrive excellence, no slipping. The issue is at 100 kmp the revs do not drop to around 2,000 and 3,000 rpm's like it used to. I ran like that about 500 km.i dropped the transmission undercover and my word the filter was black but the oil was still reddish and no smell. Incidentally I put a new transmission shifter cable and used to battle to get it out of park but other gears changed fine. The cable I used was bought from a v8 shop in South Africa and was twice the size of original but we made it work. I retired the engine. Checked for damaged hoses all good, took out IAC valve and cleaned it out, changed MAP sensor, that's were I am. Today I want to take out EGR valve and clean, when I play with the temperature sensor that controls idle on top before the TBI there is a fluctuations, but when the engine warms up the idle drops so I presume that's working, any further inputs thanks guys God bless you all for your time and services. Regards Allan Chetty
Mar 26, 2020 at 11:15 PM
