high pressure power steering hose
1995 FORD CONTOUR
193,000 MILES • 2.5L • 6 CYL • FWD • MANUAL
FRED MCCAUGHEY
high pressure power steering hose leaks badly on top side, need to replace it. Where is it located? underneath?
Jun 24, 2016 at 2:20 PM
CARADIODOC
  • 34,306 POSTS
The hose is screwed into the rack and pinion steering gear. If you see a rubber o-ring on that end of the new hose, that end is allowed to swivel, so do not over-tighten it in an attempt to stop that. Always thread the soft metal line nuts in at least two or three turns by hand to insure they are not cross-threaded. If you need a wrench right away, it is cross-threaded and will damage the steering gear.
Jun 24, 2016 at 2:48 PM
