High oil consumption
2001 NISSAN MAXIMA
200,010 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
FARHAN2149
  • 32 POSTS
Hi my car is Nissan Maxima 2006 3.0 gcc spec the car use very high oil consumption with no sign of leaking and smoke from exhaust. I am using total 5w30 for 10,000 km and now my car is 5,000 km and I lose one liter oil. What I notice only is that at cold start up if open door car smell exhaust until warm up with no sign of smoke coming out from exhaust. So where is the oil going? There is no leak and no smoke I am one hundred percent sure.
Dec 11, 2018 at 11:18 PM
Good afternoon,
The oil is most likely burning out through the engine. The reason you do not see any smoke is from the catalytic converters and the muffler are collecting the oil inside. The catalytic converters are burning it off.
https://www.2carpros.com/articles/replace-engine-piston-rings
The rings are the most common cause for this. You can confirm it by have a wet and dry compression test done. If the dry compression reading is good and you add a little oil in the cylinder and the compression raises up then you have worn rings.
Dec 12, 2018 at 11:57 AM
