Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Nissan
Frontier
Engine
Symptoms
Idle High
High idle when transmission put into gear
2000 NISSAN FRONTIER
150,000 MILES • 3.3L • 6 CYL • 2WD • MANUAL
GLYNB356
MEMBER
FOLLOW
Tachometer/engine runs up to 2000 rpm's when I put it in gear. Prior to being in gear has normal curb idle. What is up?
May 4, 2018 at 4:46 PM
CERTIFIED EXPERT
It sounds like a TPS sensor could be out but to be sure lets run the codes to see what comes up.
May 6, 2018 at 4:55 PM
GLYNB356
MEMBER
Replaced that already, This is happening when the shifter is put into gear. Educated guess it is a sensor on the gearbox. Really a question of is it?
May 6, 2018 at 7:03 PM
CERTIFIED EXPERT
I do not think it has anything to do with the transmission. Is the check engine light on? Can we run the codes to see what comes up?
May 7, 2018 at 11:23 AM
