High Idle when engine is warmed up while in park
1989 FORD PROBE
223,000 MILES
89PGTALEXD
I have a 89 ford probe gt, when i turn my engine over and it warms up it idles between 1500-2000 rpms if i drive it for a little bit it ends up dropping back down 750 , but itll still rev up to 1500-2000 rpms randomly and them stop and go back down to 750. I dont know if its the IAC valve or if its my throttle position sensor. I have checked some of my vacuum lines and from what i see there arent any leaks. Should i adjust my valves ? Or what? Im in the process of replace the valve cover gasket and oil pan gasket and timing belt cover gasket as well as the crankshaft seal . Will any of these things help my idle lower ?
Nov 14, 2013 at 7:08 PM
The IAC is responsible for idle speed. That is where I would start.
Nov 15, 2013 at 5:42 AM
94FORDPROBEGT
  • 16 POSTS
It's the idle sensor, it goes out on probes a lot I have to replace mine good luck finding the parts man. My 94 has a lot if discontinued parts.
Mar 20, 2014 at 1:01 AM
