Long story but I think it may all be related.... 2.4L 4cyl. 2002 Toyota Camry SE...automatic. no turbo. American built. 185,000 miles.
March of 2015 had to replace starter. Had to remove air filter housing(AFH) to access the starter. Attached to the back of the AFH was a VSV. (OEM #90910-12199) While detaching lines, I broke one nipple on VSV. Not even sure of it's function but tried to rig a fix (not 100%). Shortly after (within the next week) it set a CEL and code which has stayed on since but I didn't really notice any difference in how the car ran. >> to present time.
2yr old battery went dead. Needed to replace alternator and battery, but when I hooked the new battery up, I had low idle and stalling at stops. This did not get better after a number of drives. So looked up solution video's and decided to do several things as long as I was going to replace the alt.
Ordered new alt., VSV, PCV, and got throttle body cleaner and MAF cleaner.
Replaced badly gunked PCV. Cleaned MAF (wire was black with carbon) and inner elements too.
Carefully cleaned throttle body taking care not to disturb butterfly position. Cleaned with toothbrush both outer area and inner area behind butterfly.
Just behind the butterfly was an opening (port for IAC valve?). I tried to at least get repeated spray with cleaner into the small opening.
Replaced VSVButtoned it all up.
Started. Took out for a good drive. Several over the next week. Check engine light is now gone and has stayed out. Computer reset to about 750rpm and stayed that way for about a week more.
Now, on cold start up, it revs to about 1000 - 1100rpm's and stays there until put in gear. Then it goes back to 750 and is rock steady. Overall I think the engine is performing better. Sounds and runs great.
But could a still dirty IAC be causing the high idle? I didn't really even see it when cleaning the throttle body, and assume I would have had to remove the TB to access the IAC.
Also, while removing the air intake ducting I had to remove lines from another part that looked somewhat like the VSV on the back of the AFH. In fact I had to remove and reattach a number of air (vacuum?) lines and wonder if I may have caused another leak. After all these lines are 13 years old now, but I see no collapsing or cracking of them.
Can you steer me in a likely direction?
Apr 11, 2020 at 1:10 PM
(Merged)
