I got a p0171 and a p0174 code. I found a vacuum leak at PCV and replaced it. The van started working perfect and the code CEL turned off. Later that day I was driving home from work and the van shut off on freeway 4 times. Then when I finally got it home I found that it had a high idle between 2,000 rpm's and 3,000 rpm's. Starts higher and levels off at 2,000 rpm's I tested IAC and TPS. I also cleaned MAF and checked for more vacuum leaks and found none. I am at a loss. Please help.
Feb 14, 2020 at 5:17 PM
