Hello, I have an issue with a high (around 1,000 rpm's) idle when (and only then) the engine is warm and it is set on P or N. When put on D it goes down to around 700. I have inspected the vacuum and the secondary air hoses. With one exception (I put a picture of the idle control valve hose crack for you to verify if that could cause such symptoms) they all look decent.
Would you have any advice?
Best regards!
Chris
Best regards!
Chris
Dec 30, 2018 at 7:26 AM
