Just to make sure I understand the issue, you have a high idle. The way you are describing it makes it seem like it could be another issue.
However, if the idle is high then we have a number of things we need to check.
We need to start by confirming the engine that you have. Is this a 3.6L V6 and does it have anything added to it like a turbo? You noted an engine that is not offered on this vehicle and there are no turbo options so if it was added to the engine then that will bring in some other possible causes.
The leading cause of a high idle is a vacuum leak. So here is a guide that will help with this:
If we find no vacuum leak, then here is a guide that will take us to the next steps of high idle issues:
https://www.2carpros.com/articles/engine-idles-too-high
Lastly on this vehicle if there is an issue with the throttle system then there will be codes even if the check engine light is not on so let's check for codes.
Let me know about all this info and we can go from there.
Thanks
Jan 16, 2022 at 11:47 AM
